- Laptop memória 32gb-os/Kingston KCP432SD8/32/ 2TB NVME SSD PM9A1A 50ezer
- Trident Z5 RGB DDR5-7200 CL34-45-45-115 1.40V 32GB (2x16GB)
- Asus H110-PLUS/ i3 6100/ ingyen foxpost/ garancia
- Samsung Galaxy S9 4/64GB / 12 hónap jótállással!
- 0perces! Samsung Galaxy Book5 Pro 360 2in1 Core Ultra 7 256V 16GB 1TB 16" WQXGA+ AMOLED TOUCH 1évgar
- Jabra Speak2 75 MS Teams USB-bluetooth hangszóró
- Huawei Quidway S5324TP-SI-AC - 24G, 4SFP, L2, managed switch
