HookR
Például:
- Chieftec IX-01B
- Chieftec IX-03B
- Gigabyte MIB-T5140
- LC-Power 1320MI
- Silverstone ML05*
- Silverstone ML06*Esetleg:
- In-Win BP655 / PB659 / BP671
- In-Win Wavy II (IW-BMR651)* SFX táp helyére mehet akár 2db 3.5"-es HDD, csak csinálni kell neki rögzítőkeretet.
Gigabyte B85N Phoenix hivatalos oldal - [link]
"The GIGABYTE GA-B85N Phoenix is equipped with exclusive Pulse LED lighting on the underside of the PCB, providing a signature look for any custom PC build. The soft-glowing orange lighting elegantly phases in and out during system operation, bringing to life the GIGABYTE B85N Phoenix. Controllable through BIOS, users have 3 options including "Always On", "Off" or "Pulse" mode."
- BESZÁMÍTÁS! ASRock B650M R7 7700 32GB DDR5 1TB SSD RX 7900 XTX 24GB Fractal Design Pop Air RGB 850W
- iPhone 14 Pro 128GB 100% (1év Garancia)
- GYÖNYÖRŰ iPhone 13 Pro Max 128GB Gold -1 ÉV GARANCIA - Kártyafüggetlen, MS4368
- IT Megoldások és szolgáltatások
- 206 - Lenovo Legion Slim 7 (16IRH8) - Intel Core i7-13700H, RTX 4060
