Archttila
Egyebkent nagyon tetszik az MSI z170i de a VRM nagyon gyenguszra sikerult.
However, the main problems are the lack of both a full-length M.2 port, which means you won't be able to use some of the fast M.2 SSDs out there, including Samsung's SSD 950 PRO, and USB 3.1. These are two of the latest technologies likely to compel users into a Z170 upgrade, so this is a shame. It's also not the best overclocker, with 4.6GHz being the limit no matter which overclocking method we tried - most other boards hit 4.8GHz but this seems to be a weak spot for MSI at the moment. The MSI Z170A Gaming M5 performed similarly and only the super-expensive Z170A XPOWER Gaming Titanium Edition managed to hit the magic 4.8GHz number.
Mert ugye ha mar 6600K es Z chipkeszlet akkor tuning, es lehetoleg stabilan... stb stb. Az M.2 80mm es USB 3.1 tamogatasa/hianya pedig valoban szegyen.
Valoszinuleg ez a lap kiesett, igy mar csak az ASRock maradt.
- GIGABYTE B550 AORUS ELITE V2 - Gari 2027.07.22. -ig - Eladó!
- Kingston FURY Beast 16GB (2x8GB) DDR4 3600MHz
- Kingston FURY Beast RGB 32GB (2x16GB) DDR4 3200MHz (Beszámítás)
- iPhone 15 Pro Max 256GB 88% (1év Garancia) - AKCIÓ
- AKCIÓ! Asus Z170-A Z170 chipset alaplap garanciával hibátlan működéssel
- Dell Latitude 5411,14",FHD,i5-10400H,8GB DDR4,256GB SSD,WIN11,IR kamera
- BESZÁMÍTÁS! 4TB WD RED WD40EFAX HDD meghajtó garanciával hibátlan működéssel
- ÚJ Lenovo LOQ Intel Core i5-13450HX, 24GB, 512GB, RTX 5050(8GB), FHD IPS 144Hz
