Archttila
Ha volt már akkor sorry:
Project SideArmD, undecided NCASE project [link]
Prototype 1 Specification:
Case Dimension: 330x230x130mm, ~9.9L
Overall Dimension: 340x235x130 including protrusion+feet
Motherboard: Mini-ITX
CPU Cooler: Up to 60mm
GPU Limitation: Dual-Slot up tp 315 Long, 142mm Tall (excluding power connector)
PSU Limitation: SFX and SFX-L (working on Flex Power Supply for next revision)
HDD Limitation: 2 x 2.5" HDD/SSD (one up to 9.5mm thick, 3-6 may be possible for the next revision with short GPU)
Power Button: 12mm Vandal Switch (recessed, custom)
Special Feature: Custom made PCIeX16 riser, Dual 92x25mm exhaust fans at the top, CNCed solid aluminum handle
Material: Sandblasted + Anodized Aluminum, 2.0mm Panels, 1.5mm Chassis
- Apple iPhone 13 Pro 128 GB Graphite 1 év Garancia Beszámítás Házhozszállítás
- HIBÁTLAN iPhone 14 Pro 128GB Space Black -1 ÉV GARANCIA - Kártyafüggetlen, 100% Akkumulátor
- ÁRGARANCIA!Épített KomPhone i7 14700KF 32/64GB RAM RTX 5090 32GB GAMER PC termékbeszámítással
- Bomba ár! Lenovo X1 Yoga 3rd - i5-8GEN I 8GB I 256GB SSD I 14" FHD Touch I W11 I CAM I Garancia!
- TP-Link Archer C1200 Wireless Dual Band Gigabit Router v2.0
