flashpointer
újra kapni az iponon a CHIEFTEC BT-04B 350W-t ha valakit érintene :T
- ASUS ROG STRIX B550-F GAMING Eladó!
- BONTATLAN ÚJ DDR5 RAM VÁSÁR - CORSAIR / G SKILL / KINGSTON / 1X24 2X16 2X24 2X32 2X48 DDR5 RAMOK
- Kingston FURY Beast RGB 2x8GB DDR4 3200MHz CL16 - Gari 2033.10.21.- ig - Eladó!
- Akciós kisWorkstation! Dell Precision 3570 i7-1255U 4.7GHz / 16GB / 512GB / Quadro T550 4GB FHD 15"
- 27% - ASUS VivoBook S15 OLED! Snapdragon X Elite / 16GB DDR5 / 1TB NVMe Notebook!
- BESZÁMÍTÁS! Gigabyte Z270 i5 7600K 16GB DDR4 256GB SSD GTX 1060 3GB Zalman Z1 CHIEFTEC 500W
- HP Elitebook 840 G3,FHD,14",i5-6300U,8GB DDR4,256GB SSD,WIN11
