Archttila
Köszi! Mondjuk ez se kutya
pár adat tőle (HardForum)
CPU hovers around 65 and GPU around 50 under load. If it's a long session then the GPU creeps up to 55
CPU is a 6600k @ 4.5, GPU is GTX 1070, Core 2126MHz, Memory 9188Mhz
Fan speed under load is around 60%: ~ 1600 rpm at full load for both fans.
FYI bottom radiator fan 100% is 2064rpm (Silverstone FW121) , rear radiator fan 100% is 2893rpm (Silverstone FW91)
- 32 Gb Gb G.skill Trident Z Royal Silver 3200 Mhz CL14 Beszámitok! (16 Gb-ra bontom igény szerint)
- Eladó 32GB (4x8GB) DDR4 3000MHz CL15 RAM G.Skill Ripjaws V
- G.SKILL Ripjaws V 16GB (2x8GB) DDR4 3000MHz
- Kingston HyperX FURY 8GB (2x4GB) DDR4 3000MHz
- Corsair VENGEANCE LPX 32GB (2x16GB) DDR4 3600MHz (Beszámítás)
- MSI Thin GF63 - 15.6"FHD IPS 144Hz - i5-12450H - 8GB - 512GB - RTX 3050 4GB - Win11 - Gari - MAGYAR
- LG G8X ThinQ OLED Dual Screen Dual SIM 6GB 128GB Meridian Quad DAC Hibátlan szép állapotú Garancia
- szuper akció!! 200db+ REFURBISHED - DELL Docking Station WD19, WD19S (akár 3x4K felbontás)
- Dell Pro Plus 14 Core Ultra 5 238V 32GB 1000GB FHD+ TouchScreen ProSupport Plus gar: 2028.10.07
- Samsung LH55CSPLBC 55" LCD monitor
