- ASUS Prime B550M-K alaplap 24 hó gari
- Asus ROG Strix G G531GT - 15,6"FHD IPS 144Hz - i5 9300H - 16GB - Win11 - GTX 1650 - MAGYAR
- Dell 14 Latitude 5430 FHD IPS i5-1245U vPro 4.4Ghz 10mag 16GB 512GB Intel Iris XE Win11 LTE Garancia
- HPE Aruba switch, 48G PoE+, 4SFP+, L3, Smart managed
- GYÖNYÖRŰ iPhone 14 Pro 128GB Deep Purple -1 ÉV GARANCIA -Kártyafüggetlen, MS3933, 100% Akkumulátor
- Honor X7D / 6/128GB / Kártyafüggetlen / 12Hó Garancia
