- G.SKILL Trident Z5 RGB 32GB (2x16GB) DDR5 7200MHz
- ROG STRIX B660-F GAMING WIFI
- HIBÁTLAN iPhone 14 Pro 256GB Space Black -1 ÉV GARANCIA -Kártyafüggetlen, MS3235
- REFURBISHED - DELL Docking Station WD19S + 130W töltő (ELKELT)
- JBL Charge 5
- KARÁCSONYI AKCIÓK! GARANCIA, SZÁMLA - Windows 10 11, Office 2016 2019 2021,2024, vírusírtók, VPN
