Archttila
DONT use the EKL Black Ridge on a AM4 Mainboard! If so with much caution!!
Funny how you say " just install it correctly " while using a backplate from another cooler... Just got the AM4 mounting kit for my L9i today, used that Backplate and i could achieve higher mounting pressure without bending the mainboard... temperatures dropped 5-8°C
- Kingston HyperX és FURY 16Gb (20-22k) és 32GB DDR4 (47k) laptop ramok párban is 2666Mhz/3200Mhz
- HIBÁTLAN iPhone 12 Pro 256GB Graphite-1 ÉV GARANCIA - Kártyafüggetlen, MS4518, 100% Akksi
- iPhone 11 Pro 64GB 100% (3hónap Garancia) - AKCIÓ
- Logitech MX Master 3S for MAC
- BESZÁMÍTÁS! EVGA XC3 ULTRA RTX 3070Ti 8GB videókártya garanciával hibátlan működéssel
- SK Hynix PC811 2TB PCI-E 4.0 x4 nvme SSD 7000/6500MB/s
